Group: DynoMotion Message: 9216 From: Toby Rule Date: 2/18/2014
Subject: KM_MainStatus.GetKAnalogBitsStateOutputs returns wong value?
I have a bit that can be set high by the program running on the DSP, but is usually low.  Every time It is set high, I print a message to the console, so I know that I am not setting it high.  It is bit 147, which is bit 3 on the KAnalog digital outputs.
I am checking the value of this bit from the PC, using the KM_MainStatus.GetKAnalogBitsStateOutputs function.  Once in a while, for this bit, the function seems to return True when the KFlop has not set the bit to true.  The next time I check it, it has returned to False, which is what I expect it to be.
Are there any conditions where KM_MainStatus.GetKAnalogBitsStateOutputs will return the wrong bit value?  I’m updating the status object prior to checking this value, using kmController.CurrentStatus.
Will a communication error cause this to happen?
Toby
Group: DynoMotion Message: 9224 From: Tom Kerekes Date: 2/18/2014
Subject: Re: KM_MainStatus.GetKAnalogBitsStateOutputs returns wong value?
Hi Toby,
The bit should not return high unless it is set high.  The Global Status is normally returned on a "best effort" basis for status updates.  If something has the KMotion Token locked for more than a specified timeout the status request is not made.  There should be some indication this occurred.  The SimpleForms.cs example has a method of reading global status that works well.  If it is critical to get the current state of that bit it may be better to read it directly.
Group: DynoMotion Message: 9225 From: Tom Kerekes Date: 2/18/2014
Hi Toby,
